Re: New member: No TA, low pH: Advice?
Thanks for all your help! I will repost the results tomorrow! Thanks again.
dmanb2b said:yup...12 lbs should raise your TA to 70 or so...plus the borax you have already added should put your TA somewhere around 80....just broadcast it over your water surface and keep the pump running...I just checked it on http://www.poolcalculator.com
As melt says...now is a good time to start reading pool school...right after you get that TA and PH up
