- Jun 11, 2010
- 2
Trying to get my pool clear. Cloudy right now, been fighting algae. I can see to the shallow end, and probably 4 feet of visibility before its to cloudy to see the bottom.
HTH 6-Way Strips claim Total Hardness is around 200-400
When I run the K-2006 test:
25 ml sample
20 drops of R-0010
5 drops of R-0011L- On swirling, it turns purple instead of red.
It mentions that if the sample turns purple, instead of blue then add extra titrate(R-0012) at the beginning, but I'm not even getting to that step, not seeing the red to start adding R-0012. If I add R-0012 at the beginning, I still get Purple isntead of red.
Any help would be appreciated!
First year trying to open a pool, just moved into the house in November. Believe its a vinyl pool.
16x32 Inground Pool
FC=3.8 (added shock, will re-check in a couple hours and add bleach)
CC=.2
PH=7.2
TA=110
CYA= was 0, added stabilizer 6/14
25 ml sample
20 drops of R-0010
16x32 Inground Pool
CC=.2
PH=7.2
TA=110
