Well after 2 plus years I'm one of them, yes a converter from Baqua. First year was wonderful then well it's been a year since I've seen the bottom of my pool. Every three - 5 days I'm at the pool store spending $35.00-75.00 and nothing but cloudy water. The kids want to through me in with a brick around my neck with this heat. My test kit should be here tomorrow. Here's what I have so far as readings.
Baqua Sanitizer 28 Before adding 2.5 Gallons Saturday Morning.
Baqua Oxidizer 2
PH 7.6
Alk. 61
Calcium 19
Copper 2
Well I started the conversion Sunday afternoon with four gallons of bleach then four more before bed. Monday still no reading for Chlorine, added four more in the morning still no reading 4 hours later, four more before bed. Today first thing added four more gallons and here we are 4 hours later and I now have a reading of probably a little more then 5 ppm on my inexpensive tester. I also have hockey puck sized piece of chlorine in the return line.
So am I on track?
Also the other readings such as the Calcium Hardness is that something to worry about since I have a vinyl liner?
Should have added the color scheme. LOL
Started out cloudy, then light brown for a while not long though, then green and now a light lime green. Although barely I can see the bottom.
I have one of them automatic vacuum's should I use it at this point? Doesn't seem to be any garbage on the bottom from what I can see.
Baqua Oxidizer 2
PH 7.6
Alk. 61
Calcium 19
Copper 2
So am I on track?
