- Apr 25, 2010
- 184
- Vinyl
- Liquid Chlorine
Just received the liquidator and am reading all i can find on installation. Am i correct that the check valves are not needed if the liquidator is above pool water level? If so i can do without them as my pump is above water level. I will convert to 3/8 in. upgrade when i install it.I found a pipe plug on the bottom of the in line chloronator but i do not believe it will give enough pressure. I will use the pump drain plug for one connection and I have a perfect place just after the filter to drill and tap.
I'm a little "leary" on drilling and tapping my pipe, can someone talk me thru the process and list bit and tap sizes... or does anyone know if the clamp assembly with tube adaptor that comes with the liquidator is available in 3/8 inch size.
many thanks for the help!
