Just let it settle down on its own.klroahs said:Do I just let the chlorine settle itself down, or is there something I should do to correct it? I am sorry for this, I am trying to get my numbers closer to what you have here than the stores' printouts.
Luckily, I measured the final FC after dark, so I will still see if it drops overnight.
Did you turn off the SWG? If it's on during the night, that invalidates the overnight FC test.
Re. overshooting the FC numbers, there are a couple of things that might be going on...
If you used 0 for "now" and it really wasn't, then you'd end up adding too much. (And I ain't sayin' why this particular goof occurred to me, nope.) But you want to test your FC before you go figuring out how much to add, so you know where you're starting from.
Or, your guess for the gallons is too high. It's easier to figure that out when you're not shocking the pool, so let's make sure you don't need to do that first.
--paulr
