- Sep 7, 2009
- 379
- Fiberglass
- Pentair Intellichlor IC-30
I really thought I was going right, then I got some strange readings today.
Previous Readings (last Sunday)
FC: 2
CC: 0.5
TC: 2.5
PH: 7.5
TA: 110
CH: 180
CYA: 0
Low CYA, so I took a baby step of adding 4 lbs of 96% CYA (HTH from WalMart) via sock in front of a return early last week.
Today's readings are really a mystery to me, specifically the FC.
FC: 18
CC: 0
TC: 18
PH: 7.5
TA: 130
CH: 160
CYA: 20
We are having a rock path laid leading to the pool, so I left the solar cover on for the past 4 days or so to keep the dirt down and we have not been in since last weekend. I did hit the "boost" button a couple of days ago on the SWCG after the CYA was in to push up the chlorine a bit as I needed to get more FC in since I now had some CYA.
I did the FC test 2x so I am pretty sure I did it right.
I am going to take the solar cover off to let the sun burn off a little chlorine, but I could also use a little advice from the masses here.
I am also a little confused by the recommended levels as called for in the Pool Calculator. They do not seem to match up with what is suggested in the threads. If someone can post recommended levels, I will begin to aim for them.
Thanks in advance.........
FC: 2
CC: 0.5
TC: 2.5
PH: 7.5
TA: 110
CH: 180
CYA: 0
FC: 18
CC: 0
TC: 18
PH: 7.5
TA: 130
CH: 160
CYA: 20
