Thread: Confused on which Goldline model to get
    New Above Ground Pool going in on Wednesday and I am now considering an SWG.
    After spending almost all day reading on the forums it seems like a Goldline model would be a good choice and relatively moderately priced with fairly straightforward install.
    I have seen several different model #s and I am not sure what I need to get.
    Pool is a 27' Round Above Ground Pool (i.e. just shy of 20k Gallons)
    From what I am reading here I should get something that should handle double my capacity in order to run the SWG less.
    I should mention that I have a Waterco T450 Sand Filter and Waterco 2HP Aquarite pump.
    I should also mention that my equipment is about 50 feet from my pool (i.e. that's the pumping distance). Not sure if that matters or not but thought I would toss it out there anyway.
    Please advise.
    Thanks
    Greg
    27' x 52" Round Lomart Sandstone AGP
    ~ 18,000 Gallons
    Hayward S244T Sand Filter 300lb
    Hayward 1HP Matrix 2 Speed pump
    2" Plumbing - 50 Foot run buried 18" Deep - Widemouth skimmer and 1 return with eyeball
    Compupool CPSC24
    Re: Confused on which Goldline model to get
    I suggest the Aqua Rite designed for pools up to 40K. The 20K model will probably work, but the 40K unit is less likely to have any problems and is a better deal in the long run since it will last longer.
    Ok so is it the same actual system but I need a different cell (ie a 40k cell)?
    Greg
    ~ 18,000 Gallons
    Compupool CPSC24
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    The T15 cell and system for up to 40K gal.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    Hmm,
    $400+ difference in price between the 18k and the 40k, yuck.
    Greg
    ~ 18,000 Gallons
    Compupool CPSC24
