for Sean:
I have a 30,000 gal concrete in ground pool and am considering installing one of the new Autopilot Digitals but am confused on what size. I have read that sometimes the size advertised is for a 24hr/day pump running. I only run my pump (single speed) 10hrs per day. So what size should I buy?
Also, I have a 2hp single speed pump with 60ft3 DE filter and 2inch PVC runs to my pool approx 60 ft away. Based on my pump curves I think my pump flow is 120gpm to 140gpm. The Autopilot website says a max of 100gpm. What impact will occur if I install the Autopilot anyway with the SWG loop that is sold with the digital? I do not have enough room to install another bypass loop
