queenofmyswamp said:
this morning, still a lot of total chlorine and no free chlorine. I added 4 1-lb bags of di-chlor (almost double the recommended shock amount) and half an hour later, still tons of total but no free registering. Help!! Throwing $20 of shock in there (I'm out of bleach) for nothing is really killing me......
To be sure, now.... You're using the powder and drops?
It turns Barbie Pink when you add powder. You add drops and swirl until it goes clear. That's FC. Then you add the other drops. Does it turn pink again? If it does, you have CC and you add the 871 again, until it goes clear. That number is CC. Add the two to get TC.
It's easy to get confused, because the drop-only test is different.
Edit: I read your post history and see you're using K-2005. Here's how they do it.
Chlorine (Free, Combined, Total) Test
1. Rinse and fill small comparator tube to 9 mL mark with
water to be tested.
2. Add 5 drops R-0001 and 5 drops R-0002. Cap and invert
to mix.
3. Match color with color standard.* Record as parts per
million (ppm) free chlorine (FC).
4. Add 5 drops R-0003. Cap and invert to mix.
5. Match color immediately. Record as ppm total chlorine (TC).
6. Subtract FC from TC. Record as ppm combined chlorine (CC).
Formula: TC - FC = CC.
One test adds numbers, the other subtracts. Be sure you do it right.
