Melt In The Sun said:
This is a fantastic post everyone should read before believing any PB b.s. I learned alot from it after hearing about Variable speed pumps, Hydrolics explains the WHY of how the savings are achieved. 2 things you want for the lowest electric bill.
1. A pump just big enough to turn your pool once every 6-8 hours and the timer set to turn it just once
2. The largest suction and retun pipe you can afford. (this lowers "total dynamic head") which is the resistance your pump has to overcome to get the flow in GPH to the pool you need.
Bigger pipes are easier to push through, keeping the pump and everything elese the same for comparision, just like the straw example above. Let me give a example. My builder ran 2 2" suction lines, one for the skimmer, and one for the main drain, He ran one 1 1/2" line for 5 inch and a half eyeball returns. The pad is 5 feet above the pool and around the corner 60 plus feet
my DE filter clean reads 16 psi running on my 2.2HP(real HP) Pentair pump. IF I changed the pipe (unrealistic now being IG) or the builder wasn't soo cheap He would have run larger suction and return and maybe matched them. I would get lower HEAD :-D my pump would become more effecient and I could look at the pump curve and instead of 49 feet of head alowing 90 GPM flow I could easly be at 130 GPM
Then I can simple divide the pool gallons by 130 to get how many mins to run the timer then divide that by 60 to get the number of hours to set the timmer to. Now instead of 3.7 hours a day to turn the pool once I can set the timer 2.5 hours
Thats a 33% reduction in time which Directly translates to a 33% lower electric bill!
So right now I pay 0.10/Kwatt hour and the pump runs 111 hrs/month In this example at 22amps@240v(11amps per phase)
so she sucks 2,640 watts, think of that as just over 26 100 watt lamps turned on in your house. That means this pump consumes 2.64 Kwatts/hr or 26 cents
So 3.7 hours at 26 cents/hr per day times 30 days =$28.86 per month
BUT run bigger pipe ONCE and let's calculate the savings
2.5 hours at 26 cents/hr per day times 30 days =$19.50 per month :-D
that saves over $110 EVERY year you run your pool, assuming you run year round. And If you run the pump longer the $$ savings are more!
Conclusion: Bigger pipe is just like insulation in your house, If you buy now up front you will save Money and be "green"
I think the 2 suctions (main drain and skimmer) should be min. 2 1/2 inch and the return 2 or 2 1/2" min. for any pool around 20000 or less. I think mine are skimpy and thats how builders make more money off you and compeat with others.
If you can affor bigger like all 2 1/2 or multiple 2 1/2 DO it!
Look at it like this, In the above example we saved 33% on the electric bill, Would going one size up on all the pipes from what the pool builder spec'ed out going to cost you more than an extra 33% just for the pipe/fittings cost pf the bill?
Maybe close but probally not so GO BIG there is only One time to do it right and thats now
