Results 1 to 7 of 7
Thread: Anyone try the wireless ePool monitoring system?
    GregH's Avatar
    Aug 2009
    Dripping Springs, TX
    32
    At the risk of being beaten senseless with everyone's TF-100 test kit boxes, I was wondering -- anyone try the ePool wireless chemical monitoring system that Leslie's sells? I'm not looking for it as a test kit replacement, or something to tell my how much acid to add. More as a wireless temperature gauge with a Chlorine/pH indicator that warns me it's time to go test the water with my kit. Anyone try it? How far off from a TF-100 FC and pH measurement is it typically?
    20,0000 gal gunite IG pool, built May 2016. Jandy VS ePump, Jandy 60sfDE filter, AquaLink controller, PureLink salt water chlorinator, with Pentair Rainbow in-line chlorine feeder. Use a Taylor Total Poolcare DPD test kit. Heated by the Texas sun.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Anyone try the wireless ePool monitoring system?
    If you search for "epool" at the bottom left of the screen, you can find some threads talking about it. Consensus is it's a piece of junk.
    GregH's Avatar
    Aug 2009
    32
    Interesting. I tried searching within the forum before posting this question, and it didn't find anything. Still doesn't. The google search below redirects back to some old TFP postings on the subject. Looks like a couple of people have tried this, with frustrating results.
    Oct 2009
    3,899
    Yeah, the two search things are a little confusing. Sounds like you figured it out!
    GregH's Avatar
    Aug 2009
    32
    Yea. I was really interested in the wireless temp, but the pH reading caught my eye. I don't expect it to be very accurate, but if it would still be useful if was like my truck speedometer -- always off, but by the same amount. Something to warn me to get off my lazy .... and go test the water.
    Oct 2009
    3,899
    If you're interested in wireless temp, try this: http://www.troublefreepool.com/pool-...or-t19328.html
    So far, it seems to be working pretty well for nearly everyone (including myself).
    Lana537's Avatar
    May 2009
    The Triangle, NC
    242
    Quote Originally Posted by GregH
    At the risk of being beaten senseless with everyone's TF-100 test kit boxes.....
    Greg! Thank you so much for a much-needed belly laugh! That is really funny!
    Lana
    23,600 gallon, refurbished 1960's inground concrete, Jandy sand filter w Jandy 2 hp variable speed pump, Pool Pilot Digital SWCG+Chemtrol 2100+CO2 tank; PebbleTec White Pearl with 10% Cobalt Blue Dark Beadcrete by Olympic Pool Plastering, Georgia. Taylor K-2006 Test Kit; Aqua Check Salt test; LaMotte borates test, and Jack's Magic Sequest test kit; SparklyPoolitis level: extremely high.
