In my ongoing search for good sequestrantt which is readily available in Honolulu I cames across this:
Simplicity's Pool Surface Cleaner
MSDS here:
http://www.appatek.com/MSDS/SIMPLICITY/Pool Surface Cleaner.pdf
My idea would be to mix it in say a bucket of water of "?" quarts and pour it into the pool.
The item comes in a 12 oz tube and is relatively inexpensive.
As I am no chemistry major I wonder if those of you who are would consider this a good or bad solution? If good how much of the cleaner should be mixed with water and by what means (it is rather thick and is not in liquid solution), and how much cleaner would be needed for 10,000 gals? Also how often and in what does should a maintenance solution be applied? After introduction to the pool how long should the pump run?
Initially entering into the water it does foam a little, but only a little.
Thank you for considering this somewhat crazy idea.
MSDS here:
