Help please!
We were uncovering the pool a week ago, water was clear (dead alge on the bottom), corner of the cover sliped into the pool putting in some leaves and crud, fished the debris from the bottom, (lokks like swamp now), hooked up new sand filter w/new sand, filtering swamp water, clean skimmer basket and backwash daily. Took water to be tested today, readings are as follows:
fc 0.2 ppm
tc 0.2 ppm
cc 0.0 ppm
ph 7.9
hardness 130 ppm
alkalinity 40 ppm
ca 10 ppm
copper 0.14 ppm
iron not run
total dissolved solids not run
phosphate 0.00
Not sure what my next move is? What do I do next.? Thanks deb
fc 0.2 ppm
tc 0.2 ppm
cc 0.0 ppm
ph 7.9
hardness 130 ppm
alkalinity 40 ppm
ca 10 ppm
copper 0.14 ppm
iron not run
phosphate 0.00
