I just got everything running and am looking for chemical recomendations to balance my water.
Also need to know if my pool is about 20K Gallons. 20*40 IG, Liner, 3 feet to 9 feet deep
Temp = 53 deg
CYA = Less than 30
FC = 1 PPM
PH = 7.4
TA = 120
CH = 280
Salt = Drop Test (2800) Jandy Aquapure (2.5) Think the electronics are off when water is cold so I did the drop test with my kit.
Water is cloudy but can see drains in deep end. Just started filter
Also can you also tell me the recomended ranges for all the tests for my saltwater pool.
Thanks
Temp = 53 deg
CYA = Less than 30
FC = 1 PPM
PH = 7.4
TA = 120
CH = 280
Thanks
