Thread: "The Pool Cleaner" ?
    May 2008
    florida
    112
    I purchased the Pool Cleaner many months ago but only trying to set up today. This is probably a stupid question but it talks about using the regulator valve if there is no 3 way valve for suction control. What 3 way value are they talking about. I have a designated port for the cleaner, my skimmer and main drain are on separate lines. Is that what they are referring to? I just don't want to screw this up as I had it so long and never tried to use it.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: "The Pool Cleaner" ?
    Yeah, at the equipment pad you likely have a valve to open and close your dedicated cleaner line. Adjust the suction there.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    May 2008
    florida
    112
    Thanks! I got it going but still adjusting a little.
