In my pool I have a very small opening which is used if the pool needs to be filled. The whole is about 1/4 inches wide or so. There is always a steady stream of water that is flowing from that part of my pool. It does not seem like a lot of flow. Is this something normal or could I have an issue. I did a backwash recently with the full clean about a week ago and the pool water level has seem to have risen after I had it close to the correct water level. Not sure if the flow from the fill up part is the culprit or something else may be. We have not had any rain since then either, so that eliminiates that as a culprit.
Hopefully all this made sense.
Thanks.
Thanks.
