A vinyl liner doesn't have to worry about CH being too low; you do want to know if it's too high. CH of 0 is possible but does sound suspicious. Try this alternate technique: Take your sample, and put in maybe 5 drops of R-0012 first. Then do your R-0010 and R-0011; if it still doesn't turn red, I'm inclined to think CH really is zero. If it does turn red, continue with the R-0012, remembering to count the first few drops in your total. (Adding some R-0012 first is a trick for working around interference from other stuff in the water, it's documented on the Taylor website.)kcjonz said:I think I did the CH wrong last time.
I redid it twice tonight and it never turned red indicating calcium. I assume this means a reading of 0.
Does this sound correct?
Do I even need to worry about calcium with a vinyl liner?
kcjonz said:I suspect my CYA may keep going up slightly over the next day or so????
Now on to the pH.
Was going to use soda ash but have been mulling over going the borate route.
I am just curious as to how safe borates are for children, as we have a child who tends to ingest water when swimming.
