- Mar 9, 2010
- 35
Mark,
I suppose the main factor in going with the higher HP was a greater "comfort level" that I wouldn't be under-sizing. Also, I am unsure of the real implications of the SF number. I read (somewhere) this would allow handling of higher loads for short periods. If it is going to take a continuous 1 HP force then the 1 HP WFE-4 could more easily handle the load. I agree it seems a "bit oversized" but for running the suction side cleaner I also read (somewhere) that this type of cleaner required more HP.
Using the "equivalent length" worksheet from the Engineering Toolbox, the numbers came out with 23 FT of loss. Since the Hayward is only 1-1/2 in/out, it's probably the bottleneck in the current setup. When the pool was rebuilt everything went to 2" except the line for the Kreepy (1-1/2) and the old main drain (1-1/2 copper). The pressure gauge on my filter has never gone above about 4 psi so I'm assuming there is lots of room for increased discharge side flow rates and hopefully shorter run times. Also to get the Kreepy to move at a decent clip I have to set the Jandy so the skimmer is barely swirling, so to say the 1HP Hayward is doing the job is I suppose a bit of a stretch (although the pool stays very clean).
I'm probably at the stage where I'm just confusing myself even more by looking at more data. If you think the WFE-4 is too much pump for my setup let me know. The WFE-3 is in stock and I could get started on the install today without worrying about the old Hayward disintegrating.
Rich
Rich
