Thread: What type of heating system do you recommend?
    Hi,
    We live in Southern California. We have a 16x32' IG 26,880 gallon pool with an automatic vinyl pool cover. Over the weekend I successfully installed a new Sta-Rite DE filter. During the installation, I removed an old and rusted Purex Tropical Isle NG heater that's gone unused for four seasons now. Now I'm thinking I'd like to install a new heating system to extend our summer a bit. Natural Gas is inexpensive during the summer months. I've had bills of only $18 at times.
    Would NG still be a good choice (as opposed to a Heat Pump) and if so, what BTU rating would you recommend for this size pool? The water temperature averages about 72 in May but I'd like to bump that up to around 83-85 degrees starting on Friday and ending on Sunday. Thanks for any responses.
    30000 gal.
    Pentair 60 sq. ft. DE filter 150 gal. per min.
    IG 20X40 Free Form gunite/plaster
    2 hp Purex pump
    Corona, Ca.
    South Central NJ
    3,192
    Re: What type of heating system do you recommend?
    1st, a 16 x 32 with a 3-1/2 to 8' depth just several hundred gallons under 20,000 gallons. Unless your dimensions are off or your depths are deeper, you needed to know that.
    2nd, you will want a solar cover too. This will reduce the overnight losses due to evaporation. It will also help the pool stay a little warmer in the sun, and reduce chlorine loss because less water is exposed to air, reducing evaporation.
    Adding: Forgot you have an auto-cover. You don't need it but others without would.
    3rd, find out if your gas meter can accommodate a pool heater's demands, and if not, how much is it to get a bigger meter.
    4th, The size you want is a 400,000 BTU unit. This is the largest residential size. It works fastest and has the same efficiency as smaller models. Think of it like this: 1 BTU = energy needed to heat 1 lb of water 1 degree. 1 gallon- 8.35 lbs. It will take about 165000 BTUs to heat your pool one degree. A 400K heater will run about 84% efficient. Losses due to surrounding conditions with the solar cover in place may add another 5% loss and more without the solar cover. That amounts to about a 2 degree rise per hour of operation. Smaller heaters are available but that means you need to run the pump longer, not cheap in your neck of the woods. Your going to burn the same amount of gas to get to where you want to be and to hold it.
    Have a great day!
    Scott
    Owner of - PoolGuyNJ LLC
    Quote Originally Posted by PoolGuyNJ
    Have a great day!
    Scott
    Excellent advice.
    I am in so cal as well, and have 12 panels and a 400K btu unit.
    It cost me 5K to relocate and add a bigger meter so be careful you can run into more cost overruns than lockheed very quickly.
    If you add solar you can get away with a lower BTU unit as the 2 can be additive and really kick your pool up when needed (during the day of course)
    I would NEVER build a pool without solar again and have used my pool more in the last 2 year than I did the 10 prior years because I can afford to keep it hot now and can heat it up quickly for guests in the offseason without it taking days to do so.
    Let us know how you go, and if you want to stop by and see what I have going on im happy to show you. my pools at 78 today off the roof alone using a 750 watt (1HP) solar tap speed. If I need more than that I can kick the gas or run the epump faster - or both.
    Uncle Dave
    20K Gallon Gunnite pool/900 Gallon in ground Spa/2HP WhisperflowSpa
    Pentair Master temp 400/Hayward Sand WZeobrite/Jandy RS-8 Aqualink/Jandy 2HP Epump
    12 - 4x10 Panels/Zodiac G3-T5 / BBB
    Another vote for solar if you have somewhere to put the panels.
