Results 1 to 12 of 12
Thread: Tear in my winter cover
    Oct 2007
    Asheville, NC
    43
    We had about 12" of snow this past weekend. Way above what we normally get around here. When the power came back on we put the pump on to start pumping out what water we could. There is a thin layer of ice on the top of the cover with slushy water underneath. I, foolishly, tried to break through the ice to try and see how much water was on the cover (it is really weighed down). I managed to tear the cover about 3". It is near the edge and I think we could reach it to patch it. My question is this, what sort of patch can I use on a winter cover, can you use it in these cold temps and get a good seal? Any advise would be appreciated.
    Johanna
    1984 vintage 16x32 Doughboy vinyl AG w/deep end, Sand Filter
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Tear in my winter cover
    Is it the pool liner you have torn or your pool cover ?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Oct 2007
    Asheville, NC
    43
    Oops. The winter cover. Edited my post.
    Dec 2009
    Central Massachusetts
    2,690
    I wouldnt bother with it. 3 inch rip is not a big deal, IMO.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I agree, I wouldn't worry about it until the weather warms up ....
    Les
    Helpful Links:
    Oct 2007
    Asheville, NC
    43
    Hmm, my only concern is that in trying to get the water off the cover I will just be pumping water out of the pool. Ok strange thought. What if I pump the water from on top of the pool into the pool underneath the cover? The cover is so stretched out I'm afraid it may collapse. I want to raise it up some. Whatta ya think?
    Dec 2009
    2,690
    If the tear is on the edge and pretty small one at that, you shouldn't have to worry about pumping water out of the pool. Its only a small tear, don't fret over it.
    Did you put a pillow under the cover to help hold it up over the winter?
    Oct 2007
    Asheville, NC
    43
    No, I've never used a pillow.
    South Central NJ
    3,192
    Was/Is your cover taut over the water or laying on the surface? It should be laying on and draped over the edge. Torn covers should be replaced.
    Scott
    Owner of - PoolGuyNJ LLC
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I've tried a few products to mend tears in tarps, I would recommend tarp tape or gorilla tape. Regardless of which one you use they both work much better when the temperature is warmer. I personally find the gorilla tape to be stickier, but if you do try to put it on this time of year I would recommend trying to get the area as dry as possible with a rag and then use a hair dryer to get the area as warm and as dry as possible then apply the tape.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Oct 2007
    Asheville, NC
    43
    My cover was laying on the surface. It has a lot of water on it. I'm pumping it off. If a little water comes up through the tear I'm thinking it won't be a big deal until all the snow melts and I can deal with trying to patch it. I like the tape idea. It only needs to last a few months now!
    Oct 2007
    Asheville, NC
    43
    My boyfriend had the brilliant idea of sticking a fun noodle underneath the tear! It keeps the tear off of the surface of the water. Now if it would only warm up a bit I will try to put some tape on it and remove the noodle.
    Thanks to everyone who posted.
