Switched my jacuzzi with a C5 board from 110v to 220v. The transformer smoked so I changed it out to a 220v transformer. My control panel kept cycling and showing a FLO error. Checked pipes and can not find any air in them. Tested by jumpering pressure switch and pump will turn on for a few seconds and blow the jets, then stops and I can hear pressure build up in heater as water is heating. Then after a couple minutes it repeats. After 24 hours temp was only at 85 degrees. Ideas?
