chem geek said:
I would say that it's mostly saturating the water with calcium carbonate and maintaining reasonable water chemistry (i.e. not letting the pH get very low and not dumping acid in one place, etc.). Regular brushing is nice, but probably not as important as the water chemistry.
Also, not letting the pH get high for any length of time especially if water is going to sit uncirculated with or without debris sitting on and staining the bottom. Avoid anything that will make stains in the pool that will necessitate acid cleanings. That includes unbalanced water over a period of time, metals in the water without using sequestrates to reduce or eliminate the staining, letting the pool become a "frog pond". I'm pretty convinced the iron staining in my pool, that I have to keep on top of, comes from our sand and silt (loads of it year round) as our fill water doesn't register any iron. Avoid
any additions of any pool product that contains any amount of copper. For instance, there are several algaecides that contain copper. The HTH 3" dual action chlorinating tablets (sold at Walmart and other places) contain copper. And many other products. Copper staining is just about the hardest metal stain to remove.
Organic staining from leaves, etc, will usually fade, over time if the chlorine levels are
constantly adequate so you usually don't have to use drastic measures to remove them. Best policy is to never let anything organic sit for very long on the bottom.
Anyone correct me on this but I think some algae will etch into the plaster surface.
Use a light hand when brushing with stainless steel brushes.
Don't let your cleaner drag objects around the pool that it cannot pick up.
Make sure that any cleaning tools, rakes, skimmers, brushes, etc., have adequate protection of metal parts, like plastic or rubber coatings, that can scratch and gouge your plaster.
Any metal that stays in the water for any length of time needs to be good stainless steel, like ss screws. Be aware of hair ties with little metal joiners, bobbie pins, clips and other hair helpers, that may be sitting on bottom causing little annoying metal stains.
Muratic Acid is very much heavier than water. Even small amounts will sink down the sides and straight to the bottom like lead.
I'll add more as they come to me.
I've been and expert pool plaster abuser for 23 years.
That is prior to finding TFP.
