Thread: intelliflo VS+VSRS or VF ?
    MY pool is
    30x16 freeform gunite
    2 lion heads
    1 sheer
    1 skimmer
    suction line for cleaner
    aquacal heat pump
    aquarite SWG
    2 main drains
    no spa
    no automation
    hayward C1750 cartridge filter
    want to replace my current hayward super II 2HP pump with either the VF or the VS+VSRS
    HELP
    South Central NJ
    3,192
    Re: intelliflo VS+VSRS or VF ?
    What is the plumbing size?
    Are the lions and sheer tied?
    What cleaner are you using?
    Can you post a picture of the the equipment pad?
    Scott
    PoolGuyNJ
    Owner of - PoolGuyNJ LLC
    pipes are 2" suction and 1.5" returns.
    i don't think the sheer and the lion heads are tied in together
    heater is beeing replaced with aquacal heat pump soon. using the poolvernugen suction 4 wheel cleaner
    poolguynj
    thanks for your help
    South Central NJ
    3,192
    The heater doesn't look old. I'd put the heat pump after it. Having both is convenient.
    What are the 3 unconnected line?
    Either will work.
    Do you need an SVRS in your local?
    Is getting the flow data from the pump rather than by calculations important to you?
    Is a set flow rate vs. set speed critical? Not usually.
    Both have internal timers and up to 8 presets.
    Scott
    PoolGuyNJ
