Hi all,,
We have a small pool that we'd like to keep up year around (San Diego, CA) water is expensive! That said, we want to get this right. I have a few questions:
1) should we seal the seams with quick seal or the like? If so, how do we do that?
2) is it normal to have condensation under the pool? We had an easy set pool that started leaking at the seam we set up the new metal frame to drain the water into. We moved the easy set pool out of the way then put the water back in the easy set while we set up the new pool. We only left the water over night but this morning while putting the water back into the easy set noticed condensation under the new pool. Is that normal?
3) should we put anything between the concrete and pool, other than the tarp?
