It's best to stick with one thread as long as it's the same general topic, which makes it easier to scroll back and reread the history. Which I just did.
TA 115 is not low, it's actually on the high side. Not necessarily bad; but it's contributing to the increase in pH.
CH 400 is not the end of the world either. The curious thing is that as the temperature goes down, the risk of scaling also goes down! Calcium is weird that way. SO, I think you don't need to do a big drain/refill to lower CH before closing. You maybe want to drain a little more than you would normally, when you close, so the spring refill will help with the CH; but no worries before then.
I don't want to say anything specific about closing, because I've never done it (too warm where I am), just wanted to correct the info about TA and CH.
--paulr
--paulr
