I recently bought a house that came with a pool. The pool is above-ground but built into a deck with galvanized steel walls and what looks like some kind of a foundation underneath. It's about 18'x8', rectangular, and I guesstimate it to be about 4500 gallons.
That pool is in need of a lot of fixing. It needs a new sand filter (the existing one is cracked, I guess water was left in it over the winter), probably a new pump, and definitely a new vinyl liner. The plumbing is a 1.5" combination of hard PVC pipe and flex pipe, partially below ground but mostly above ground. One flex pipe has a large leak and needs to be replaced. Since I'm changing everything I want to install a salt water system as well.
First, I'm having a fair amount of trouble finding a pool company to do that work (I'm in NJ, Ocean county). A whole bunch of places don't do anything with above-ground pools and a few above-ground people don't want to deal with hard wall rectangular pools. I found one which gave me a quote. The quote looks suspicious to me, but I have little experience with pools and am looking for guidance.
The liner replacement is quoted at $1.5K. I think it's reasonable. The pump and filter replacement including install are also about $1.5K. OK, I guess. But then they quoted me a Pentair salt water system (probably an IC-20?) for $2.2K which seems excessive and a full re-plumbing of the pool for $3.2K which looks wildly excessive to me.
The Pentair system by itself is about $1K and neither a $1K install charge, nor 100% markup look reasonable to me. As to plumbing, there are three intake lines (two inflows + a skimmer) and one return line. The below-ground parts are a few feet in length and a few inches deep. I'm fine with new plumbing being all above ground, anyway, and for $3K I can spend a weeking gluing pipes together.
Any thoughts, comments, ideas?
