Alright, so we're installing a fence around our IG pool. Backdoor goes to pergola covered patio, patio goes to pool sidewalk. Pergola posts will be used as fence posts and 8' double gate (4' gates x 2) will put in between the pergola posts. It appears the previous owner and/or contractor wasn't too concerned about centering and symmetry when installing the patio, pergola, and/or pool sidewalk. It seems there is no good way to center the gates.
Option 1: Center w/ pergola
This makes the most sense to me but the pergola offsets to left (when at back door) and it wouldn't line up w/ the patio line. The pergola's curtain rods directly above where the gates will be are centered this way (if that matters).
Option 2: Center w/ pool sidewalk
This seems like it would look the most centered but that does not appear to be case (after I moved the patio furniture away). This also would not line up with the patio line.
Option 3: Center w/ back door and patio line
Offsets to right (when at backdoor) and right door would hit pergola posts when completely open
Another option I haven't thought of?
What do you all think? Picture below of measurements plus all 3 options w/ 8' pole and 4' broom stick to simulate gates. PS we are more concerned about how it looks from the house side more so than how it looks from the pool side.
Measurements and best drawing ever:
[/IMG]
Option 1: Centered w/ pergola
[/IMG]
[/IMG]
Option 2: Centered w/ pool sidewalk
[/IMG]
[/IMG]
Option 3: Centered w/ back door and patio line
[/IMG]
[/IMG]
