Greetings:
During Pool Opening this year one of the quick connect fittings on the Polaris booster pump busted. It was the pump's feed line coming from the T on the return side. We improvised a "quick fix" by a trip to Lowe's. Here's what I did:
1. I removed the quick connect fittings, and cleaned all the old silicone sealant out.
2. Replaced the quick connect fittings with a threaded/barbed adapter similar to this, using teflon tape on threads and a bead of silicone sealant at the top of the threads: Shop BrassCraft 3/4-in x 3/4-in Barbed Barb x MIP Adapter Fitting at Lowes.com
3. Attached a custom cut section of a hose similar to this: Shop EASTMAN 3/4-in x 10-ft Reinforced PVC Reinforced Braided Vinyl Tubing at Lowes.com
4. Secured the flex hose with clamp rings similar to this: Shop Murray 10-Pack 3/4-in - 1-1/2-in Dia Stainless Steel Adjustable Clamps at Lowes.com
The fix worked well enough to allow pool opening, everything is running fine. (It looks really nice and clean too, bonus!) But would it be better to consider replacing the whole smash with this kit: https://www.amazon.com/Polaris-R0617100-SoftTube-Connect-Swimming/dp/B00V03PWG8 ?
Kelly
Kelly
