So odd... why does water flow up the air blower line when I turn on the spa drain? As far as I know, the drain and the venturi jets are not connected. But when I turn the pump on and open the spa drain, water goes (slowly) up the air blower line feed. The Air blower is positioned about 4 feet above the waterline, so I know it is not gravity feeding this.
As a result, I can not isolate the spa from the pool. I always have to heat the spa and have the heated water trickle over into the pool. If I try to just heat the spa (open jets to spa and open drain to spa / close all other pool valves) the water slowly rises up the air blower line.
NOTE: I do not have a Hartford Loop installed, but because the air blower is far above the waterline of the pool, I was told it wasn't necessary.
ADDITION: We did just have the pool surface re-finished, going from a white to dark color plaster. AS a result I had the crew replace the spa jet heads with black eyeballs. Is it possible that they did not put the nozzles back in the jets? Would not having a nozzle cause water to go back into the air line? IF SO... why would this only happen when the spa drain is opened?
