Need help with pool size
May 20, 2018
24
Valatie, Ny
The picture is all that I have to go by other than a hand written note saying it's 34000gal. If it was square it would be easy. I suck at math.....
Thanks in advance
If you can break the pool up visually in to sections, then use PoolMath app (found at top of page) to help you, you might get a better idea.
Another way is to use your pool chemistry to zero in on the volume. Test and adjust your pH or FC level to a particular level, then add x amount of MA or liquid chlorine and see if you reach your goal. Again use PoolMath to help you.
Got a pic of the pool so we can see?
Maddie :flower:
BINGO! I estimated your pool size at ~24000, and when entered in to PoolMath, 129 ounces of 8% will take you from 4 to 7.5.
So its about that, IMO. Over time you should be able to see if I'm off as you change chemical parameters.
Maddie :flower:
