- Jul 14, 2009
- 3
I purchased a used Dimension One 2002 Californian and absolutly love it. This is my first time owning a Spa and thanks to these forums i have been able to enjoy it for several months without issue. So after about 4 months it was finally time to drain and refill, when i first turned it back on with the new water i received the low flow error, but after bleeding the circulation pump the error went away and the circulation pump and the heater turned on. When I turn on the #1 Jets they function properly on both low and high but when i turn on the #2 Jets, the pumps turn on but only a few bubbles come out of jets and only for a moment . Everything was functioning perfectly before i refilled the tub, is there some kind of Bleeding procedure i can do to get them running again? Oh I guess i should mention too that i replaced the Ozone Generator after emptying the tub but my guess is thats the reason i needed to bleed the circulation pumps???
Any help would be greatly appreciated!
