I am not the tallest person in the world, so vacuuming my pool from the outside has always been a challenge. we just set up (as in filling while I type) an Intex 12' x 24' pool so I got an auto cleaner to help me out this year. So my questions are: 1. Should I still used a surface skimmer? 2. Now that Intex pools have 3 in and out hoses instead of 2, I reverse my hookup so that I can run that surface skimmer. The auto cleaner also needs to be hooked up to that larger hole as well, but obviously in the outlet position, not in. My sand filter is a 2450gph and I also use a salt water ionizer. I have not yet come up with a way to merger the 2 small inlets into one, but the pool is still filling. Any ideas? We get a lot of pollen so a surface skimmer has always been a must. I also got a solar blanket for this pool which I have been lead to understand helps keep some of the surface dirt down. But how do you get them out of the pool without dumping it all back in there?
Thanks in advance. I know this must sound crazy!
