Oceania C-740010 - Above Ground Pool Filter and Pump System, 1/2 HP pump, I uses ZeoLite Sand, would show you a pic but it is not letting me upload it.
Sounds like a sand filter. Are you checking the pressure gauge to see when it climbs 20-25%? Backwash it when the pressure rises to clear the filter up.
It is a sand filter but I am using ZeoLite sand instead if regular filter sand, much better filtration like a DE filter, I backwash the filter everyday I never let the filter pressure raise.
Some pool owner patience is needed towards the end of the SLAM process.
Your pictures are showing an improvement each day. Keep up the good work! Your filter is trying it’s hardest to remove all the cloudiness from the water. Let the pressure build up some to help remove the fine particles.
No changes just adding liquid chlorine and sweeping. Now I am going out of town for the weekend for my youngest Son's wedding will see how it is when I get back Sunday night.
That should be fine if you're only gone a couple of days. You could even go up to FC 26 or so and not sweat it.
I'd say there's a good chance that you pass the OCLT right now, even though you still have just a little bit of cloudiness. Just let that pump run and hopefully when you return, the filter will have done its job and cleared the pool up even more.
