Thread: We SAW the algea, but NO CC's on drop test! So do we shock?
    West Chester, PA
    53
    Ok, I thought I had this down, and now I'm stumped! Here's the situation in a nutshell...
    Rainy and very little swimming this week, pulled back the solar cover and had some small areas of faint algae in the shady part of the deep end. Brushed it off.
    Discovered the pump had been left to pull from the skimmer only, and the water was very high=poor circulation.
    Have been using BBB all summer with much success, haven't had to shock yet.
    Husband tested at 10 a.m. PH 8.2, FC 7.0 drop test, he didn't know to test for CC's.
    Added acid in two steps to bring PH to 7.5.
    I went to the store and loaded up on Bleach to go into Algae killing mode.
    Tested at 1 p.m. and FC at 4 and CC at ZERO!!! Tested twice with same result.
    Other numbers: TA: 110 CH:220 CYA: 30 plus a bit but not 35 WaterTemp: 81 Full Sun on pool today
    Is the sun or the algae eating the chlorine?
    Do I need to shock?
    thanks as always for the help!
    TF-100 Test Kit, 28,000 gallon IG , 3M quartz plaster '09, 48 sq ft DE filter, Heat Siphon SX5HP heat pump '09, Polaris 360 '10, Protect-A-Child safety fence
    Jun 2007
    Long Island, NY
    34
    Re: We SAW the algea, but NO CC's on drop test! So do we shock?
    It would suspect a combination of both the sun and algae. If you saw algae in your pool then you should shock it, regardless of the CC showing .5 or zero. I have just gone through a stint with some bad algae for a few weeks and my CC was either .5 or zero every time I tested.
    You need to do an overnight test. This way you can rule out the sun eating any chlorine and if there is a lower level of chlorine in the morning than there was the night before you know it is the algae eating it.
    Brian
    18' round x 52" vinyl AGP holding aprox. 7633 gallons of crystal clear sparkling water, most of the time. Hayward s166t sand filter, 1 hp pump and 2-2x20 Fafco panels is parallel. TF100 test kit and BBB!
    West Chester, PA
    53
    OK, SHOCK TREATMENT COMMENCED! DEATH TO ALGAE!
    FC 14 AT 3:15
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Maria
    FC 14 AT 3:15
    I also suggest the overnight test.
    You're done SLAMing when:
    West Chester, PA
    53
    Overnight test part of the ALGEA KILLING REGIME----CHECK!
    FC at 12.5 at 3:50--ha gotcha!
    FC at 4:30 14.5
    FC at 5:35 14.5
    I think I caught it early! I'll check again a couple of times tonight, and then do the overnight by checking first think a.m.
    thanks!
