Hi,
I've been having this pool for a few years now and this is very first time I have experienced somewhat major issue. A few days ago, I noticed the water in our elevated spa has drained to the pool water level. After spending a few hours googling and went through this forum, I have tried these steps here:
1. Checked the check valve and it seems fine but since it's a common cause for why the spa water drains, I went ahead and replace with the new valve flapper. Follow the instruction tightly and even use lube to lubricate around the ring and flapper (picture 1)
2. Checked the pool pump basket to make sure there is no debris or anything that could cause the water not flowing (picture 2)
3. No air leak front and back of the pump either (picture 2)
3. Clean the filter and check the PSI (it stays at 25 PSI). Is that low?
4. The water still drain after the pump is off. And when the pool is on, I also noticed there is no pressure coming out from the pool jets and the same with the skimmer. However, the spa jets works properly and the water overflow to the pool properly though.
One thing I don't fully understand how they work is the pool valve actuator so I couldn't tell if the valves are failed or not. Unfortunately, there is no label anywhere so I don't actually know where MAIN drain and where is the RETURN water, etc. I'm attaching the picture and if someone can kindly explain what #1 valve and #2 valve mean. Should they both turn when I switch between spa and pool mode? I can't recall how they work before but I noticed only #2 is switching 180. Should #1 switch as well? Would that be the cause for the spa drain?
Before I need to call the pool professional, I'm hoping if anyone can provide other suggestions on what other steps I can check here. Or if I can get some explanation on how the pool system works in general or based on pictures I have provided here to determine if any of my valves here are working properly or not.
