I completely neglected our pool over the winter and now it’s a swamp. Dark brown, stuff floating, even calcium build up ring around the tile. Stupid I am! Anyway i have been reading for several days on this site, but had one question. Our pool is in ground gunite with a SWG, but also has a chlorine tab dispenser that we can use when it gets too cold for the SWG work. My vacuum and hose and backwash line should be here Thursday so i can get the major chunks of algae out, and I have already received my k-2006 test kit. That test shows obviously 0 FC. It also shows PH off the scale (it took 18 drops to get the ph color to the desired range). So it seems like i will need to put about 4 gallons of muratic acid in to get the ph down to the right mark. My question is this. My CYA shows 40, which is not on the table for a SWG pool. I have the SWG unhooked and had it unhooked all winter, so I’m really just unsure at this point what my shock level should be. Do I use the normal table since it has not been using the SWG or do I act as if the SWG is working since that will be turned back on once I have it cleared up? If it’s the latter, what should my shock level be to SLAM it since it’s not on the table provided? Thanks!
