Thread: Changing Gasket Around Skimmer
    Apr 2015
    TX
    33
    I will be changing out the gasket(s) around my skimmer on my in-ground vinyl pool today. Any pro-tips?
    A few concerns I have:
    1. Do I need to put some silicone on the faces of the gasket?
    2. Do I replace the gasket on both sides of the vinyl? I ordered two gaskets. Do I need to use them both?
    I am hoping to stop a leak. Shoot me any pointers if you have any. Thanks
    14,800 gallons in-ground vinyl. sand filter. 1.5 hp pump
    PoolguyinCT's Avatar
    Jul 2014
    Connecticut
    2,655
    Re: Changing Gasket Around Skimmer
    Leave the bottom gasket alone, it is unlikely your liner is still pliable enough to manipulate it.
    If you have steel walls & see rust, abandon the job. & A\B the faceplate to skimmer throating, making a bridge.
    Apr 2015
    TX
    33
    Quote Originally Posted by PoolguyinCT View Post
    I am pretty sure I have some rust behind there as I am seeing it on the the faceplate a bit. What does "A\B the flaceplate to skimmer throating, making a bridge" mean? Thanks for your suggestion.
    Jul 2014
    Connecticut
    2,655
    A/b is a 2 part epoxy.
    Here are images of rusted panel & an expensive repair, you donít want to open a can of you know what.. & the liner had to be replaced to do the work.
