Hello you very helpful bunch,
TRi is 4 years old, I just noticed the chlorinated side of the cell has a brown residue all over it, I took it out and cleaned it (for the first time), it could be one of the cables to the electrodes rusting, not sure.
So my guess is there is brown residue going down the cell outlet pipe and the sensor / acid feeder pod, the pH sensor had some brown gunk on the glass bulb that I wiped off.
The strange issue is that with the chlorinator off (0%) the pH reads correctly at a low 7.0 (FAS-DPD) but with the chlorinator on, so I can see the chlorination bubbles the pH jumps up to 8.0 and then the acid turns on, as a temporary measure I have disabled the acid pump to let the pH climb overnight.
Very strange.
Thoughts?
Thanks for looking.
Cheers
Richard
Very strange.
Thoughts?
Thanks for looking.
Cheers
Richard
