Thread: Above Ground Spa Seep. Fixes?
    Jan 2017
    Ivins, Utah
    2
    My 8 year old above ground spa is showing signs of seepage along the sides. Not sure exactly what to do or if it's a real significant problem.
    Overall photo:
    We have very high mineral content water. Chemistry results are as follows:
    ph: I lower it down to 7.2 and after about 3 days it drifts up to about 7.8 - 8.0. I use muriatic acid.
    FC: Raise it up to about 8.0 and after 3 days it's drifted down to 1-2 ppm using germicidal bleach (8%)
    TA: averages around 220
    CH: averages around 350
    Once a year I drain the spa and clean the mineral deposit ring with muriatic acid.
    I notice there are small white 'bumps' on the interior that I suspect is mineral leaching? Could be related to the water seepage?
    The pic below shows a couple of the seeps.
    Thoughts? Do I need to address these white 'bumps' on the interior surface? Is there some sort of clear sealer that could be applied the next time I drain the spa?
    Thanks for any assistance!
    Above ground spa. Approx 1200 gallons. Gunite. Built 2009. Chlorine. 1 hp filter pump; 1-1/2 hp booster pump for jets. Taylor K-2006 test.
    Re: Above Ground Spa Seep. Fixes?
    The water coming through the wall is a leak of some kind. Maybe through the shell or from plumbing.
    The white is probably scale and maybe calcium nodules.
    The high TA probably has your CSI sky high.
    Check the CSI with poolmath.
    The plaster looks dark and splotchy. Is that the original color?
    Support the site
    Jan 2017
    Ivins, Utah
    2
    Thanks for your comments, James.
    Regarding PoolMath, when I enter my ph and FC (using the current values for TA & CH) I'm usually within the recommended range of -0.6 to +0.6. Although if I let the ph drive too high or FC too low, I'm out of range.
    I think the clouds in the sky reflected a bit giving it that splotchy look. The nodules are just slightly proud (maybe 1 mm?). Yes, it's the original color. I took another pic, but can't upload it for some reason...
