Thread: Bang for my buck Outdoor Wicker Furniture set?
    May 2016
    Dallas/TX
    333
    All,
    I am searching and searching and searching on the internet, trying to find a great wicker furniture set to put in my backyard. I am going to get a propane fire table and have a wicker set surround it. I would love to spend $1000 to $1250 on the couches.
    Anyone know where I can find a good quality set that won't set me back too much? I want a nice solid set, but it doesn't need to be the best. Bonus if the store is located in Dallas.
    Thanks!
    12K Gallon, IG PebbleSheen Blue Granite, built AUG 2016, 4 Jandy nicheless LED lights , Jandy 2.0HP VS ePump, Jandy AquaPure PLC700 SWG, PB4-60 Booster pump, Polaris 280, Jandy CV580 VersaPlumb Cartridge Filter , Jandy - Pro Series RS4 W/iAquaLink, Jandy JXi400NK 400K Heater, OK Flagstone Coping, Travertine Decking, 7 x7 Spa, Tanning Shelf, 10' Grotto, TF-100.
    May 2017
    Southern NJ
    103
    Re: Bang for my buck Outdoor Wicker Furniture set?
    Check out sears.com. They usually have pretty good deals on wicker sets -- that's where we got ours. Also have purchased wicker furniture from jet.com in the past and ebay, I think.
    30k gal IG SW gunite pool, 4-8' deep w/ 16" baja shelf; Ocean Blue PebbleSheen; well water (resin softener); Hayward Pro-Grid 7.5 lb., 60' D.E. filter; Hayward TriStar VS filter pump; Hayward TurboCell T-15 SWG; AquaCal TropiCal heat pump; Hayward OmniLogic automation, Colorlogic lights (2 large; 2 accent); Polaris cleaner w/ booster pump; TurboTwister slide (gray granite); 5' rock waterfall w/ second Hayward TriStar VS pump; TF-100 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    8,864
    Pier One often has some. See if you have any local patio furniture shops (some not-too-fancy-ones) as you'll be supporting local business and not breaking the bank.
    Maddie
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    511
    We got ours from Home Depot - Hampton Bay Spring Haven and it has held up well over the last 2 years.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,844
    What kind of look are you going for?
    I bought a North Coast Cabo couch a few years back (diff cushions than ths one) and it's held up extremely well, even through winter freeze/thaw cycles. I like the modern lines of ths one. Not especially cheap (eg. sold by our local leisure store vs big box) but better rated for weight etc. than Target-type fare. That said, I have rockers that are a close knock off from target that are doing just fine considering how comparatively inexpensive they were
    Cabo 3 Seat Sofa - All Backyard Fun
    This line also has a really neat curved couch...on the pricier end.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    May 2016
    Dallas/TX
    333
    Thank you for the suggestions, will check these out.
