Thread: FORECLOSURE -- Newbie in MD
    Mar 2018
    Glenelg,MD
    23
    Question FORECLOSURE -- Newbie in MD
    Hi everyone-
    We just bought a foreclosure with a pool and spa. We're in MD. Here's all that we currently know. Inground Pool 28x48 and 8' round spa. We believe the house has been empty for approx 2 years. Luckily someone installed a Loop-Loc cover on the pool and the spa has a thick fitted cover as well.. foam block maybe with vinyl cover? Both the pool and spa have water in them and from what we can see, peeling back a small section of both pool and spa covers, have plugs in the jets.. I've included all the information we found so far with regard to systems.
    Since we're brand new to this I'm reading all of the Pool School articles familiarizing myself with what's what.
    My first question is ... when do we start "opening" and assessing the pool? After freeze?
    What comes first? Assess the pool for debris?
    Thanks all!
    22x45 inground freeform, 8' round spa, ~41K gallons, Pentair Clean & Clear Plus CCP420, AquaComfort S125(currently not functioning), Pentair MiniMax NT (may be defunct), Centurion ??, Paramount in-floor system (no clue which one yet), Mineral Springs System MS-11(missing salt cell),
    Mod Squad JohnT's Avatar
    SW Indiana
    9,432
    Re: FORECLOSURE -- Newbie in MD
    Welcome to TFP!
    I wouldn't mess with it until the danger of freezing is past. You have a pretty big window between that and when the weather will really be warm enough to swim so there's no need to hurry it. You'd be in a mess if you couldn't run the pump and it got really cold. Not to mention you'll have your arms in cold water up to your biceps taking the plugs out.
    You might start looking for drain plugs on your equipment. Those are removed for winterizing, so if they aren't around somewhere you may need to do some searching. Download manuals and find out which items have plugs. People often store them in the pump strainer basket.
    Your covers probably kept the big stuff out of the pool and spa.
    You'll need a test kit. Tftestkits.net is where I would go. You'll be happiest in the long run.
    Taking some pictures and linking them here would probably be a good start as well so people have something to refer to when answering questions.
    Don't worry. People here have been through much worse situations. On foreclosures, usually all of the equipment is gone and the pool wasn't winterized.
    Mar 2018
    Glenelg,MD
    23
    Thank you so much!
    I'll be back after the weather warms up a bit and we no longer have to worry about freezing temps. Going to get a test kit soon, since I know I'll need it.
    We did factor in that the equipment would be toast when we bid, and although the pool tiles and spa look to be in decent shape who knows what we'll find when we pull that cover off.
    Thanks again!
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,230
    No problem for you to open in mid April. It may still get below freezing but not for long enough to cause a problem.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
