Thread: what is typical salt level of NON SWG pool?
    pookiesunshine's Avatar
    May 2016
    Cincinnati, OH
    503
    Can anyone give me a range of salt levels in pools that use regular chlorine bleach or tablets for sanitizing?
    Apparently the level of salt in SWG maintained pools are so high that acrylic decorative concrete sealers do not hold up when used on surrounding pool decks, but salt levels in regular pools are okay. So i'm trying to find out what those levels are. Sealant manufacturers are not very forthcoming so far other than suggesting that SWG levels are too high.
    Can anyone add to this:
    [QUOTE=YippeeSkippy;1377064]........
    ALL pools essentially are salt water pools. Each ingredient you add does add some salt once it breaks down, so in a few years time you might be sitting in water with about 1000ppm salt already. SWG use between 2500-4000ppm. The ocean is 35,000ppm!! ......]
    Thanks
    30000 gal inground vinyl liner;sand filter w/glass media, nuvo uv, TF-100 test kit; 25 years on Baquacil, converted to TFP chlorine in 2016
    22,761
    Re: what is typical salt level of NON SWG pool?
    I've used bleach for many years and my salt level runs about 1,500 to 2,000 ppm. Been a while since I've tested the salt level in the fill water, but if I remember correctly, it was about 200 ppm last time I checked. We've had many people report salt at or greater than 1,000 ppm when preparing to add a swcg.
    cfherrman's Avatar
    May 2017
    Hays, Kansas
    1,710
    Salt level in human tears is 9,000 ppm
    Casey
    Intex 24' x 52" closed for winter 2018, 2 Main Drains, 1 Skimmer, 1 Return, PVC
    1/2 HP Intex Pump 633T w/ Taeglus TA-40 175 lb 19.5" Sand Filter, Auqabot Extreme Robot
    TF-50 and Taylor 2006 Test Kits, Quality Well Water, Fleck 5800SXT Water Softener
    domct203's Avatar
    Jun 2015
    CT
    3,959
    Quote Originally Posted by Bama Rambler View Post
    ..... We've had many people report salt at or greater than 1,000 ppm when preparing to add a swcg.
    Put me in that camp... after 2-1/2 New England pool seasons I already had 1200ppm of salt (per Taylor K-1766) when I installed the SWG, almost half of the 3000ppm +/-200ppm required.
    Quote Originally Posted by pookiesunshine View Post
    ......Apparently the level of salt in SWG maintained pools are so high that acrylic decorative concrete sealers do not hold up when used on surrounding pool decks, but salt levels in regular pools are okay.
    Can you share your source of this info? Is this the findings of an independent study, or something from the sealer manufacturer?
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,192
    Roughly........I'd say a "normal" chlorine pool has salt levels on average of about half of what a SWG requires.
    May 2016
    Cincinnati, OH
    503
    Quote Originally Posted by domct203 View Post
    mostly anecdotal. my own pool deck was sealed w/acrylic and lasted for about 3yrs. then i converted to chlorine, then added more salt, not realizing how much salt i had already added during conversion. so i ended up with swg level salt. recoating after that lasted less than 3 months. [there's more but that is the jist].
    web search reveals various conversations on acrylics not holding up around salt. nothing definitive about what is okay. frustrating for me.
