Thread: Mr. Clean Magic Eraser & Vinyl Liner
    Jun 2007
    scottsdale,az
    19
    We used a mr. clean magic eraser to clean the vinyl above the water line a couple of years ago. I'm afraid it removed any kind of UV protection that was on there...
    The area that gets the most sun above the water line is darker. I understand that a liner can become lighter because of chlorination ...but that's on the case- The shaded areas are no different above & below the water line.
    Could/Should I wax the area that's being scorched by the sun? It's almost like the liner is getting a tan or sun rot above the water line where the sun directly hits it.
    10,000 gallon in ground vinyl liner pool. 1 HP AO Smith Corp motor 3450 rpm, Nautilus Pac Fab Filter DE. Raypak Gas Heater.
    Re: Mr. Clean Magic Eraser & Vinyl Liner
    http://www.superiorcarcare.net/four-sta ... spray.html Look here this is what i found Maybe it will help protect the Vinyl I may buy some next year myself.
    Jun 2007
    scottsdale,az
    19
    I'm willing to try it. I'd rather do that than have a cracked brittle liner.
    I would NOT recommend anyone using the magic eraser on a vinyl liner about the water line for this very reason.
    krcossin's Avatar
    Detroit Burbs
    113
    I have used the magic eraser on my liner with very good results, better than anything else I have tried.
    A product I have used on my boat that works great and has spf40 in it is: http://www.303products.com/shop303/inde ... ectant.cfm
    I might try that on my liner.
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    I highly recommend not to use the magic eraser, it's basically a micro abrasive. It WILL damage older liners, it can take the print right off... on younger liners I'm afraid it might be doing damage we can't see. According to my liner fabricator the layer that protects the vinyl is basically a clear version of the ink used to pigment the vinyl.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
