Thread: POOL STORE EXPERIENCE
    Northeast PA
    29
    I went to Leslies this morning and the young guy who worked there asked me if I needed help, so I told him I needed fas-dpd re-agents. So as he was ringing up the sale he asked me if it was for me or an agency. I told him it was for myself. He asked me if it was just for my backyard pool. i said yes. He said he never heard of someone with a backyard pool using fas-dpd. So I told him that my pool is beautiful since I know how to test my water this way! So actually it was very uneventful, but enlightening.
    Carolyn
    AG Pool 15 ft. round 4,000 gal. 100LB Hayward Sand Filter
    TF 100 Test Kit
    Carpe Diem!
    Butterfly's Avatar
    South Carolina
    10,045
    Re: POOL STORE EXPERIENCE
    Knowledge is power
    You're done SLAMing when:
    Guest
    Knowledge is knowledge, power is power and often exists on it's own.
    Arizona
    924
    I'd ask him which companies/services do purchase FAS/DPD from that store. Reason being, they just might be a service company that you at least knows cares enough to do adequate tests. In case you ever have a situation where you might need to use a pool service. Around here, most of them buy the jumbo packs of really big strips, which we all know are not adequate and they spend a couple minutes at your pool tossing in who knows what after they take a second to use their "trusty" strips. I only know of one service here that actually spends time taking care of the pools they service.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    Guest
    Quote Originally Posted by Buggsw
    Pretty much the same deal everywhere. The only ones that really do maintain pools properly are the ones taking care of commercial pools that have to answer to the health department (and sometimes that's doubful from my own experience in commercial pool maintenance! I worked would one guy who kept putting 3.6 and his FC measurement in the log for the Health Dept. using a Taylor K-2005 comparator and DPD. I questioned him on this and he showed me the 3 on the chlorine scale and the 6 on the bromine scale and thought it was 3.6 when it was actually 3 ppm. The scarey part is that he was a CPO)!
    every experience I have had with Leslies has been a minimum sale of $60 of "stuff that'll fix your pool"
    Not that I knew enough in earlier times to say that they were the right chems. or not, but ugh to their sales pitch.
    20,000 US Gallon Oval with diving well but no board :( Hayward s244t2 & Multiport SP71621
    1hp AO Smith WhisperFlo pump / basket Part 7-177450-03 / 3 returns, well drain connected to jacuzzi overflow
    baracuda version 3 run to the overflow; side hookup add in process.
