I do not have a pool. Just a hot tub.
I think discussing me, and my experience, and my own personal credentials, makes for a much more tedious conversation than the pool chemistry and methods brought up by the original poster. But for the sake of argument I'll address the topic.
I do use trichlor in my hot tub to offset the ph rise caused by bleach (it's not ph neutral as mods repeatedly claim here), and from the buffer added with top off water from evaporation. This also keeps my CYA levels from dropping over time caused by oxidation and splash out. My CYA levels drop on average one point per day. It does not take long for the dreaded confusing and complicated "moving FC target" to get away from me out of range. It avalanches in that the lower CYA levels are relative to what I think they are, the higher the chlorine are and the faster what's left oxidizes.
Using trichlor as an acid keeps CYA levels consistent (actually slightly dropping over time) in conjunction with bleach as my primary chlorine source, is the method I am using at this time. I bust the puck up into smaller chunks, then grind up the smaller pieces into a powder with a mortar and pestle, then add about a tablespoon at a time to knock my PH back down.
I believe that the chemistry is similar enough to contribute to this thread.
it will not form part of TFP protocol fr the reasons I and others have outlined
How about this proposal......
In saltwater pools, it is recommended that during the swim season, one puck should be dissolved per week, per 15k gallons to prevent CYA loss over time. Periodic CYA tests should be done, and changes to the puck dissolving schedule made to keep CYA levels from changing away from desired target.
That doesn't sound all that complicated, does it?
Are we really going argue that folks don't know how to dissolve pucks, or get confused about what that does to their pool water? Or that it is easier to hang a sock every week or whatever..... Or that it is better to let CYA levels fall lower over time so that the hanging of sock is something that happens so few times over the year that it is less work than adding the puck every week or two or three or whatever.....?
Is having a FC target moving a good thing, or a bad thing?
I feel like ya'll are being deliberately and unnecessarily obtuse here.
And also, for the record, the trichlor still doesn't dissolve as well as dichlor, even after it is ground up into a fine powder. When my pucks are used up, I will go back to using dichlor, despite its higher CYA content, because it is easier to use. I do not advocate the use of trichlor in spas.
