Hey, I have an issue where my PVC piping come out of the ground is too close to a wall to be able to remove/install a new pump (Hayward Super II). I was hoping for some advice on cutting into and adding to the existing pipe to give myself a little more play. Obviously flexible 2" PVC piping would be best for my purposes, but I'm not sure how well flexible piping would handle the pressure/elements (I'm in Tucson, so heat is the main issue). The other alternative I can think of would be to add a bunch of joints to give myself the extra couple of inches I need. My main concern is that there's very little exposed PVC to work with, as it comes out of the ground and directly joints into the pump, so there isn't a lot of room to mess up before I'm going to have to drill through concrete to get to more pipe to work with. And as a relative novice to this type of stuff, I'm no stranger to messing up. Since a picture paints a thousand words...
That's what I'm working with. Thanks for any advice!
