Thread: Are you supposed to use a silicone lubricant on light gasket
    VoR's Avatar
    San Diego, CA
    41
    I just replaced my lens gasket for my light a couple of weeks ago and today I noticed its got several inches of water inside of it again. Are you supposed to use something like magic lube or should the new gasket do it alone? Maybe I did not tighten the ring down enough?
    It's a Pentair Amerilite 500W
    9000 Gallon Gunite Pool
    Pentair 1/2 HP Whisperflo Pump
    Pentair DE Filter
    Kreepy Krauly
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: Are you supposed to use a silicone lubricant on light gasket
    I use jack's lube. When I ordered a replacement bulb for a Aqualumin II it game with new screws and a new gasket! score!
    Anyways, this has always been an issue for us; if the light is old we usually recommend a whole new light to stop issues like this from happening those factory seals can be hard to seal back up once opened. Try it again if you want, let everything dry out take out the gasket and clean it first then lubercate it and scrub where the gasket will sit with a tooth brush. bottom line is make the area where the seal is as clean as possible and lubricate the gasket.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    VoR's Avatar
    San Diego, CA
    41
    Thanks for the tips, I finally pulled it out and redid it. I used a CLR type product to get the lens and housing real clean and scrubbed with a scotchbrite pad. Lubbed it up and reinstalled. Should I run it for a long time or short time at first?
    Pentair DE Filter
    Kreepy Krauly
    Mar 2007
    Coastalish 'down easter'
    4,160
    While I usually lube the gasket - I've found that just properly tightening the securing ring is usually enough.
    How does your light ring secure and how did you do it?
    Luv& Luk
    -Ted
    VoR's Avatar
    San Diego, CA
    41
    Its a ring with two loops bent out 90° on the ends. Just a bolt through it with a nut and washer on the end.
    I'm hoping that by removing the small calcium build up will prevent leaks.
    Pentair DE Filter
    Kreepy Krauly
