Just today my pump started to trip the switch about every 30-60 minutes. I only reset it three times and then just left it off for the rest of the day. I've only lived in this house and have taken care of this pool for the past three years. In the past it would maybe trip the switch once a year...no big deal in my mind. The pump it's self looks pretty beat up and I'm not sure how old it is. Should I be looking into anything else first to figure out what's going on? I'm leaning toward just swapping it out for a new one because some other little things are broke on it as well...like the drain plugs...gone....the holes have been filled in. Also, is it really that hard to replace the pump? Looks like two screw in pipes and the power. I'm thinking because the power lines are already there it should pretty simple to switch them to the new pump. I'm no expert but have done some small electrical work around the house before.
Here is all my info.
16x32 inground pool = ~21k gallons.
Current pump: Hayward
Model Number: SP2605X7
Total HP: 0.75
Rated HP: 3/4
Service Factor: 1.00
Voltage: 115/230
Pipe Size: 1 1/2"
Dim "A": 13 7/8"
Ctn. Qty.: 1
Ctn. Weight: 32 lbs.
Any pump suggestions other than just using another Hayward 3/4 hp superpump? Looks like I can get an exact replacement for around $250-$300
Total HP: 0.75
Rated HP: 3/4
Voltage: 115/230
Pipe Size: 1 1/2"
Dim "A": 13 7/8"
Ctn. Qty.: 1
