Thread: Adding M.Acid and Bleach
    Jul 2007
    North of Dallas
    207
    Can I add the acid and bleach one after the other or should I give some time between adding the two.
    I added 2 gallons of acid this morning and the PH late this afternoon is still 8. I was going to add another gallon this evening and then a little more chlorine as it's at 0.5. The CYA was measuring pretty good this afternoon, around 70 and the Alk is high.
    Just FYI, it's a fairly new pool and I'm working on getting it balanced for the first time. My SWG has not been able to keep up as my PH was out of sight, the sun is right out in the wide open hot texas sun and I have two waterfalls (one's only on part of the time). So, I'm going to get the Chl and PH balanced manually then let the SWG take over the chlorine duties once it's balanced.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    You can add acid and bleach fairly close together, they both disperse into the water comparatively quickly. Pour slowly and give a couple of minutes between and you should be fine.
    Jul 2007
    North of Dallas
    207
    Awesome. Thanks again JL. Turned the SWG on an hour ago. Then just added 1 gallon of M Acid and 2 gallons of chl and then I'll check it in the morning. Hopefully I'll have some decent numbers.
