Thread: Proper way to add CYA
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    489
    I need to add about 2 lbs of CYA and I've read that some people put the CYA in a sock and place the sock in the skimmer until it dissolves. Two questions about that: is it necessary to use a sock? Could you just pour the solid CYA in the skimmer and let the sand filter catch it where it would stay until dissolved? Second what kind of sock is used - panty hose or a plain cotton sock?
    20' x 40' IG with vinyl liner volume approx. 35,000 gal.1.5 H.P. main pump, Polaris 280 cleaner W/ 3/4 H.P. booster pump
    Hayward sand filter, 3.14 sq ft, 62 gpm. Stenner 45 MPH10 chlorine feed pump. 1 micron final filter bags (home made and very effective)
    Marillion Fan's Avatar
    About a 1/2 hour from P.S.U.
    259
    Re: Proper way to add CYA
    If you pour it into the skimmer you can't backwash until it has dissolved usually about a week, using a sock, and I was using an old hunting sock, lets it dissolve into the water and circulating quicker.
    Some also hang it in front of the return jet to dissolve directly into the pool.
    I also found the sock worked as a skimmer sock while I was clearing up an algae bloom, so I left it in my skimmer and now water is crystal clear.
    18x33 15700 Gal Oval Above Ground
    Ranger Sand Filter w/Praher Multi Port Valve
    A.O. Smith 1.5 hp Pump
    Confer E9120 Steps
    BBB And Sparkling Clean.
    stev32k's Avatar
    Mar 2009
    Mobile, Alabama
    489
    The pool has been so clean I haven't had to backwash since the first week in May. Even now the pressure is only 1 lb above where it is right after a backwash. I've lost some CYA due to very heavy rains and the pool overflowing. We have had anywhere from 1 to 6 inches of rain per week for the past several weeks.
    I've seen other references to a "skimmer sock", but I have no idea what that is? Is it something you buy at a pool store?
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    google is your friend. here are some for example http://www.skimmersocks.com/
    pool stores may sell them. walmart may. they're on ebay too. I started using knee-hi stockings from walmart since my local one doesn't carry official skimmer socks.
    259
    If you are not looking at backwashing anytime soon, then putting the CYA into the skimmer will be alright.
    A skimmer sock is a light weight filtering sock that fits over the skimmer basket to catch smaller particles of stuff that can work their way through a filter and back into the pool.
    I have never bought them but I think they can be bought at pool stores and Wal Marts. Some use an old nylon stocking, which are just about as good without the cost of buying the actual things.
    Confer E9120 Steps
    Guest
    pour it slowly into the skimmer with the pump running, run the pump 24/7 for about 48 hours, go back to your normal pump schedule. Don't backwash for a week or test the CYA for a week.
    IF you decide to put it in a sock it is not a skimmer sock or pantyhose that you want to use since the CYA will go right though the weave. You want to use an old white cotton sock. Some CYA will escape and it's going to take a week for it all to dissolve anyway so it's futile, IMHO, unless you are battline a green pool that NEEDS to be back washed more often thatn once every 48 hours.
